Removal of the drill press depth stop threaded rod | | Bloy, I see you have removed the threaded rod that was the drill press depth stop. How did you do this? I can't see how the rod is attached to the arm.
I have decided I should move my Z-axis DRO sensor, and I intend on doing a similar mount to yours, but need to remove the rod. |
