I think the image might have been to large. Maybe the forum has a size limitation but I'm not sure. The reply to your post was that in hyperVIEW you can also simulate the fixture machining as I was showing in the image. I created an array in the same fashion as you posted in your picture above. Using ToolPath Edit allows the array in X or Y or any combination then the toolpath is saved for hyperVIEW or your controller. Optimization of tools used is automatically sorted in the save function. |
