CarbideBob,
I've never heard that too low a feed rate is bad for endmills, what is the lowest chip load you suggest for HSS and aluminum? The material is harder than nickel, I was able to scratch an old nickel with a corner of the material.
Edit:
I tried cutting a scrap piece of aluminum with the original g code, worked just fine! |
