OK no guarantees.
I made a drawing of how I think your switch works.
Confirm that I have the jumpers going to the correct terminals.
I think the remaining motor lead should connect to 9 or 12.
You should disconnect the line and motor wires and use a meter to check that the switch operates the way I have it drawn before you use my diagram.
Reason: Fix up the drawing
