I,m using cncpro to run my machine,and need a post to generate code using photov carve,tried the mach 2/3 inch.txt but get funny things happening when I run the code .I edited the code but ended up where the machine left home position ,went + x to the limit of the code then returned to 0,0 then went back to the x limit and thought that was the start point.re-wrote the code and same results.Wierd.Which post should I use that is available with Photo-v-carve to save my files to .Hope this makes sence,cheers and thanks in advance. |
