Hi guys, I am newbie to cnc machining be it metal or wood. I am in the progress of sourcing stuff to build my first CNC for milling alu and wood. I had in my mind to make wooden rotor blade. I am not sure how it should be run....length wise or fr leading edge to trailing edge? Next is the end mill to use...what dia is able to do the job? The blade is appx 20cm long and 2cm in width.
Thanks in advance
Mike
