Old 12-25-2006, 05:53 PM
dcoupar's Avatar
dcoupar dcoupar is offline
You said you already qualified the tools with the presetter, but you experienced problems setting G54 Z0. That is what my relply was meant to explain. Sorry if I didn't make it clear:
After you qualify your tool(s) with the presetter, but before you attempt to measure the G54 Z0 offset, call the tool in MDI that you're going to use to measure, i.e.: T0101 or T0202, or whatever, then when you cycle start, that offset will become active. If you then touch the face of the part and do the Z0 - Measure in the Work Offset screen, you will see that the Z absolute position is 0.
