Old 02-21-2004, 06:41 AM
John S. John S. is offline
John S. is on a distinguished road
Most stepper motors are 1.8 degrees per step.
So given from your figures that 3.6 degrees will move 15.7 cm then 1 degree will move 4.36cm
Taking 1.8 degrees and microstep this by 10 will give 0.18 degrees which will give 0.79cm on the target.
Is this good enough?
See http://www.geckodrives.com for more info on micro stepping motor drives, You need the G201.
John S.
