After looking at your conversion I thought you may want to see what I have been working on. 2 Ryobi's for 60cc's horizontally opposed. I am now working on the ignition so I can start it to see if stays together. On the ignition (cdi) I am learning new things like programming a pic and think I may have aquired enough knowledge to get it done. I have had help on the ignition and now just working out some of the bugs when you change components.
With your ignition being 180 deg. differance in firing I would be tempted to install 2 magnets (180 deg.apart)for your pickup and waste a spark as mentioned. I am not sure if mine will have the output to fire 2 coils at the same time which I will have to try or install two systems in parallel. I have my board down to 1.5 x 2.125 so far.
John |
