Old 02-20-2004, 05:20 PM
nervis1 nervis1 is offline
nervis1 is on a distinguished road
If you mean the jumper settings they are posted on the inside panel of the invertor cab. If you mean you have a new single phase transformer sitting on the floor and need to install it.....whew, I'm not going to be much help. Sounds like a job for a tech. You should consider a 3 phase, they are not that much $ and would give you 15-20% more torque.
I don't remember seeing a wiring diagram for the transformers in the manuals but check Fadals site, and look at the manuals they have there on line. There is tons of documentation there, and I haven't been through it all.
Also try Neal at Fadal in the tech dept. He'd might be able to fax you the documents you need.
