the shaft bushing is sized to go over the motor shaft, and then fit into the mill head. basically i turned a bushing so it was a tight fit over the shaft.
the key way, is a stepped keyway with the small end fitting the motor and the large end fitting the mill head. i will try and show some pics tomorrow. |
