If that .01 falls between the Z slices it makes to calculate the tool paths it will not clean up the bottom. You’ll probably have to use another type of cut to finish the final depth depending on its shape and contour. Z finish works great on steep walls but not what you want to use for large open contoured surfaces where “Planer” cutting shines. |
