Hey Syil,
I see "origin offset" and "axis offset" in the diagnostics screen, but I do not see one called "Home Switch Offset". Are we talking about Mach 2? I tried the ones I mentioned, and they did not seem to do anything.
I reversed the logic on my Z axis home switch, so now it starts to creep downward while looking for a ground (like I want it to). I am currently faking it out by waving something thru the light sensor to make it stop. It just stops, which is a good start, but I have yet to get it to back off & calculate the "fudge factor" for switch thickness. I am going to splice into my home sensor in order to ground the line with a touch-switch as planned.
Thanks, Mike
__________________ Expensive tools can be cheaper than professional therapy |
