It sound like single phasing, try setting up a resistive load between the phases out. In a pinch you could put 3 sets of 110v Lamps paired up in series. and recheck the voltage across each pair.
Your Static convertor output may not be referenced to ground, if not those readings are meaningless.
Most VFD are not BTW.
Although you should always ground the motor.
__________________ CNC, Mechatronics Integration and Machine Design.
