New here, great forum!
Also new to CNC. Recently came to a shop where Bobcad 17 is used to control an older Anaheim Control driver. Prior to my trying my hand at using Bobcad to code the cuts on an XYZ router, the other guy had made many cnc files to cut with. All his files are nothing but X,Y,Z coord to cut the entire project. When I tried this using a different machine using BC 17 I get I & J codes for radial. The router is hooked up through the AH driver and to a PC using very old G-code software to run it and it doesn't understand I or J codes. As I read through the older code it appears non modal and every arc or circle is made with nothing more than x,y,z coords. I've tried everything to replicate this same code but can't get 17 or any newer version to output code in strictly X,Y,Z without going I or J on me.
Any ideas on how to get circles and other radius objects to code in strict x,y,z output without radius codes?
Thanks |
