Old 04-29-2003, 02:41 PM
motomitch1 motomitch1 is offline
motomitch1 is on a distinguished road
200 Oz-In 6.5 Amp Bipolar Parallel
what would be a good driver for Model P22NRXA-LDS-NS-02NEMA 23
200 Oz-In
8 Wire
May be Wired Bipolar, Unipolar, Series, or Parallel
3.3 Amp Bipolar Series ~ 6.5 Amp Bipolar Parallel
2.71 Amp Unipolar Series ~ 4.6 Amp Unipolar Parallel
35VDC
1.8 Degree / 200 Steps Per Revolution
and i have a 24 v 6.5 amp power supply
would the G201 work for this motor ?
for xyz Central Machinery
This mini mill/drill machine has two speed ranges—0 to 1100 RPM and 0 to 2500 RPM—great for different thicknesses and types of material. Features a micro feed that allows the operator to feed at .002'' per line.
Heavy duty cast iron body and base for better stability. Precision machined table. Includes drill chuck & key, shaft and chuck key assembly and wrenches.
Motor: 4/5 HP, 120V, single phase
Speed ranges: 0-1100 RPM low, 0-2500 RPM high
Spindle taper: R8 with JT33 chuck taper
Spindle stroke: 8-1/2''
JT33 chuck capacity: 7/64'' to 1/2''
End mill capacity: 1/2''
Face mill capacity: 1''
Swing: 12''
Depth scale: 0 to 12'' in 1/16'' increments
Table slot width: 1/2''
Table dimensions: 15-7/8'' x 3-11/16''
Height: 33-3/4''
