I used to run a burn table and we ran propane and some derivative of it. I had to switch over to acetylene for a few days while our tank was empty and I couldn't get a good burn to save my life.
Only big difference between acetylene and propane is that acetylene burns alot hotter (i believe), and a single peice tip, so using it on a hand torch is perfect. With propane you'll need to get the proper tips and, at least with the burn table, I had a diferent tip for almost each thickness of plate. |
