rotary shoulder connections | | Wolog, i try to make with 50 Rpm but is same. The insert has a special geometry , and center tool is ok, also i trying with 0.017" deep of cut per pass, nothing. you are right, the material is SAE 4140.
Hi, CNCBoss. IŽll be thankfull if you send me some pictures when you make this kind of connections (rotary shoulder connections), i tell you that i used the tailstock because the leng of the crossover that i make is 20" or 25" and the diameter of 5" to 6", my HAAS TL-3 has 3.5" of spindle bore. Also I use steady rest, also nothing.
Thank guys for your attention,
Greetings from Peru.
Alain |
