Originally Posted by cartertool Also check your x axis gib adjustments, if the gib is not correctly set it will stick in one direction and effect feed accordingly... http://www.cartertools.com/millset.html http://www.cartertools.com/millset2.html
Also check with whoever supplied the drive and see what their recommended settings are (I don't recognize that control box - where did you buy the mill from?) |
The controller is xylotex. I bought the complete 4 axis setup on eBay.
