It usually depends on what software you use to generate the points (i.e., using rhino to run a probe will I think get you a cloud straight into rhino that can be saved as a .dxf or .dwg), but anything homegrown would probably be easiest to store in a comma delimited .txt or tab delimited spreadsheet... |
