12-08-2006, 11:54 AM
| Gold Member | | Join Date: Sep 2003 Location: USA
Originally Posted by colin1544 Hello
The boss 5 bridgeport with a ajax retrofit works great, the only thing you have to be prepared for is to get the keways on the timing belt pulleys that fit on the motors need to be opened up to 3/16" key as the origonal is a 3/32" woodroffe key. Also the motor mount on the Z axis needs a 1/8" spacer plate on the face as the bore in the casting is not big enough bore to accept the motor register boss. Apart from these points which are not mentioned in the instructions it is a relatively simple upgrade.
GOOD LUCK Colin |
I found this post.
Darek |
