Solids Recovery System? If that's correct then yes we did. What can we expect from it?
We had issues with that auto stand off on the first day. It probably works ok on thicker materials, but on thin stuff it will deflect the material, then the clearance becomes less.
the install guys said they have seen pendants that other customers rigged up somehow, I may look into this. Might be possible to make something like some of the Mach guys made.
__________________ If you try to make everything idiot proof, someone will just breed a better idiot! |
