Little more clear on concept | | Sorry, I was a little vague.
I want to use new controls/drivers, and PSU
The machine I'd like to make should have a table size of min"
24" x 32". Z height should be 6" to 8" (this I will build).
The motors I have seem to work fine. There nema 23 unipolar 6vdc,1.2a. I have four other 12vdc units.
I'm running TurboCNC, which seems fine right now. I'm not much of an electronics man, but am learning. Soldering skills are min at best.
Comprehension is very good.
Basically in a nut shell, From an experienced persons point of view, I would like to know what you would purchase if you could get everything from one spot.
The machanics I can handle from this end.
TIA
Neil |
