  #10
Old 12-04-2006, 02:03 PM
MrBean's Avatar
MrBean MrBean is offline
Gold Member
MrBean is on a distinguished road
Here's the files for the lower half of the main body.
There are 5 files in the archive:
The main DXF file.
A CamBam file for the main pockets.
A CamBam file for the Holes.
A Gcode for the main pockets, cut with a 3mm endmill.
A Gcode for the holes, cut with a 1.5875mm endmill.
The CamBam files make it easy to change tooling parameters such as the tool size etc, then regenerate a new tool path and create the newGcode file.
Just select the machining op from the tree view on the left, type in your new cutter size, then right click the maching op and choose "Generate Tool Path". The tool path should now update using the new parameters, then right click on the machining op again to "Generate Gcode File". Easy peasy.
First run the pocketing gcode, labelled 3mm cutter. Then, leaving the part in place, run the gcode for the holes.
Regards Terry.
ID:	26694   Click image for larger version
