Old 11-28-2006, 09:35 PM
Shotout's Avatar
Shotout Shotout is offline
Shotout is on a distinguished road
BMackinnon
The only inserted cutter I have seems to be to much for the machines we have. It is a 1.25 Dia Serria Sine III endmill, but I just can't seem to tune it in using Valanite's recommended SFM for the selection of inserts for it. I forgot to say the bore size as pointed out. It was 2.371 +.001 -0.0 as specified by the customer.
Geof
I had thought to use a helical toolpath which would have been equivalant to a single flute cutter. Mainly to have the convience of set it and forget it so I can keep the other machines we have cutting. I had thought to not use the offset boring head to prevent the need to adjust it for a finish pass. I figured it would be slower, but if it was a consistant and held my tolerance and gave a nice finish I thought it might be worth taking a little longer. If it is going to be an excessive amount of extra time, or give me a poor result then I need to figure something else out.
I'm basically trying to learn different ways to do the same job. Now that I have some help taking some of the load in the shop off of me I'm trying to expand my bag of tricks and learn more about this trade.
Scott
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
