Dan, not sure what you are asking or trying to do. in general, keep grinding away from the lathe if you can, the grit is very bad for it. what is a fixed nut? are you saying you want to cut a hex on a piece of round stock? make a file rest is one way to put flats on stock held in the lathe |
