Hi vadmvc, Thank you; You should have some prices within a couple of hours..
I do have some questions...On the shaft pulley: is the shaft integral (6061 turned down) or a fitted part either press or running fit? If it is part of the shaft pulley I'll need an over-all length or some-thing to describe the shaft length. And as for the wheel: What's the out side diameter? Other wise, they seem to be pretty sriaght forward parts.
Thanks, Eddie |
