Exodus: ".... u can't do right click and select what every geometry that u are looking for "
Sounds like a former Mastercam user.
Depth: I've always thought that you should specify depth in the direction you want to drill. You mentioned Conversational programming. I programmed Heidenhain for years. They always put in the direction. Because, theoretically you cpould drill Up if you wanthed to. What is you have a right angle head pointing to the right, you'd be drilling X+. If it was pointing to the left you'd be drilling X-.
Mike Mattera
__________________ Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com |
