Old 02-08-2004, 05:52 PM
routalot routalot is offline
routalot is on a distinguished road
I have known instances when routing wood or other materials when the cutter creeps out of the collet.It has usually been because the cutter was too deep in the collet before the collet nut was tightened.Could I suggest that when you install your cutter, you retract it a shade before tightening the collet nut as this will leave a gap for the cutter to move into as the final tightening takes place.
