Thread: tapper bore
Old 02-08-2004, 02:44 PM
Gibbsgod's Avatar
Gibbsgod Gibbsgod is offline
Gibbsgod is on a distinguished road
Try these
You can do this 3 ways (more also but, these are the most common)
#1 If you have Solids, just select the faces of the taper hole and use a contour operation.
#2 Create a helical taper with the "Create Helix" Plug-in from the pulldown menu (plugins pulldown)
#3 Create a contour operation and change the wall angle to our desired taper. (The icon next to the tool depth settings in the contour process)
Good luck.
GG
