bbuonomo,
consider that on most controles the tool data page and the fixture offset page are two different G codes in the program, are you sure you are defineing the fixture/work location with the correct G code?
Also do you need to "home" the nachine before you set tools or find the work location?
I know that some machines I've run,would run w/o homing first but wouldn't know ware they were, some won't start w/o homing first, some pick up right ware they left off.
Examin your situation carefully I'm sure it must be somthing subtle that you're missingin your procedure...?
merl |
