  #31
Old 11-14-2006, 02:54 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by David Da Costa View Post
Hi Joe, yes, if you the mean the one under the cdrom it's the one that came with my Xylotex kit.
Yes once I get everything in it's final place, I will try to keep the wiring as far away from interference sources as possible. Of course that is the risk of an all in one setup.
Worst case I have a separate box that I will just re-install the controller stuff into if I find I am having any interference issues.
Any recommendations on shielding?
just use shielded wireing, also lateron you may want to beef up the power supply. run it a while with the 24v and see how it performs, I use 36vdc with 200oz motors and works good. 80ipm is what i cut at mostly.
joe
