Old 11-14-2006, 08:40 AM
DareBee's Avatar
DareBee DareBee is offline
Monkeywrench Technician
DareBee is on a distinguished road
EVEN if LINCOLN tells you to use a gas conversion kit, you will also at minimum need a teflon liner, aluminum won't feed through a steel liner.
IMO you need a 255 and a spool gun (gas of course) as a minimum welder requirement.
I will digress (possibly) - after you spend a bunch of money setting up your machine for aluminum you MAY be able to weld foil
www.integratedmechanical.ca
