plasma programming question | | Hi.
I have to write a driver for a Torchmate plasma machine.
I have written dozens of drivers but all for Routers with Z movement and am having a bit of trouble wrapping my head around a plasma tool.
I am used to raising the tool to Safe Height, travelling to the start point and then plunging into the material.
Are G00/G01 Z moves not required for plasma tools?
Do you just G00 xy to start point, turn the tool on and then G01 xy moves to cut the job.
Also, the machine in question seems to support Plasma and router /engraver tools with tool changing commands.
What happens if the job starts with a Plasme tool, and then callls for a router bit. Do you just start with G00/G01 Z moves at that point.
Hope im not being too vague.
Should have added, is there place to view example gcode for Torchmate machines
Reason: addendum
