LazyCAM can convert .dxf's to g-code, but it can be a bit buggy, depending on the particular .dxf's
You can download Mach3 and play around with it. Near the end of the install, uncheck the box that syas "install driver". This will install it in simulation mode, so it won't hog your PC while it's running. LazyCAM can be found under the file menu in Mach3. Downloaded the newest 2.0xxx series version.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
