YOU WILL FIND ALL MY ANSWERS IN RED
The software appears to be very clean and professionsal.
But I have many, many questions:
What are the conditions of the trial versions? Is this a time sensitive thing or reduced functionality or both?
From the site:
"PartMaster Level 2 Milling is a system designed to
create complete programs for NC and CNC milling
machines and machining centers. PartMaster Level
2 is completely icon driven so that no programming
language needs to be learned."
What does it create the program from - a DWG, DXF or do the parts get created within PartMaster? You will either create your part in Partmaster or you can import a .DXF file.
Will the PartMaster allow imports? What file types is Partmaster compatable with? Partmaster is only compatible with .DXF files how ever the Dolphin 3D CAM Level 2 will import a wide variety of files if you are looking for more solid and surface imports.
What form is the output? Is it a text file? It is a text file that can be save to the extension that your particular machine calls for. |
