Originally Posted by sunmix someone said that the 64bits processor such as AMD 64 Sempron 2800 Socket AM2 does not work for Mach3. I would want to clarify that because I'm planning to invest on a new computer running with AMD x64. |
I doubt you'll get Mach3 running on a 64 bit, why would you want to anyway, it will only cost more for the new PC (64). Just get a cheap Dell.
With Vista selling, that makes a great time to pick up an XP PC! Cheaper!
I did read that Vista 64-bit will have 2 DVD's one with 32-bit, the other with 64-bit, so you might be able to actully get Mach3 running on it (32-bit), but that would defeat the whole idea of buying the 64-bit in the first place.
So If you really need to have the 64-bit, make sure you get the 2 DVD's.
