Old 11-06-2006, 01:17 PM
ViperTX ViperTX is offline
ViperTX is on a distinguished road
Two options.....the first is pretty simple.....mount a small table the size of the stuff you normally machine in the location where you would normally engrave.....machine the surface of your small tag table...now the small tag table surface will be parallel with your engraving head.
If you are trying to use the whole table surface, then you'll just have level the whole table, before you waste any time....check with K2 on the flatness of the table, you may find that even if the table surface is level there may be areas that are within the table surface's flatness, but noticeable when you engrave.....so, now you know why there are machines made especially for engraving.
Let us know what happens.
