  #12   Ban this user!
Old 11-04-2006, 11:19 AM
MAX711's Avatar
MAX711 MAX711 is offline
MAX711 is on a distinguished road
Originally Posted by philbur View Post
mattinaustin said in his first post "I tried removing the entire spindle lowering/raising assembly" which I guess means he has removed the spring.
Regards
Phil
Thanks Phil, I can now see that I instructed mattinaustin to duplicate work he had already done. Hopefully I didn't confuse him too much. The important part of my post was the first part which talks about the hidden grub screws, they are very easy to miss because they are at the bottom of a dark hole and there's 2 of them. You remove one thinking the spindle will now move, but it doesn't because there's another one further in the hole. I suspect that might be the problem mattinaustin is having.
