Old 11-04-2006, 10:48 AM
keebler303 keebler303 is offline
keebler303 is on a distinguished road
This is just a thought and may not be correct but it may display the actual speed of the tool, that is the composite of x and y, not just one or the other by itself. If you are going 60 ipm in the X and 60 ipm in the Y then the tool is actually moving at 85 ipm diagonally. It is a pythagorean theorem deal. I would imagine this is correct because that is how mach keeps the feed rate the same on a diagonal cut as on a straight cut. If 2 axes are involved each one has to move slower to make the tool go the same speed.
Matt
