Old 11-03-2006, 11:34 AM
burbankbrewer burbankbrewer is offline
burbankbrewer is on a distinguished road
What material are you cutting? What rpm, depth of cut are you cutting at? Look at the insert to see where it is touching the material. You may need to grind the sides of the insert to get more clearance. If you look at the specs for the insert it will tell you what you can cut with it. I bet it won't include what you are trying to cut.
