  #586
Old 11-02-2006, 10:47 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
Here are updated bearing slides, I forgot the diminsion for the bolt reccess on the angle, and also the dim. for the bearing offset from the angle.
The best way i have found to make the slides is to print a templete, tape it to the angle, use a center punch to mark the holes, then just drill with a 5/16" bit, with a center punch you really do not need the step up with bits to the right size., then I mark the 0.125" reccess for the bolt along the angle, and just use the grinder with a course wheel to file it down to the depth.
Joe
