Old 11-01-2006, 04:10 PM
ajtomany ajtomany is offline
ajtomany is on a distinguished road
Trophy1B
Mike,
Attached is the file you requested. I'm not sure if your professional version will open an educational version file or not. Give it a try.
If it doesn't open, let me know.
Part of the problem you were having is that you didn't specify a depth of cut when atempting to cut the profile. Also, you can control the side the cut is made on through the Profiling dialog or by double clicking your geometry.
As far as the tool paths go, all I can say is that you need to take advantage of the layers. Create the layer you would like and then make sure that particular layer is active when creating tool paths. This is an issue I have had to repeatedly tell my students.
Hope this helps. If you have any more questions, please feel free to ask!
Armand
