I use Mastercam X2 and I had my post fixed with a g4 p1. to allow the coolant to hit the tool before it cuts. I like my TM-2 but I wish I would have bought a real machining center. The machine cuts good but, if you cut a lot of stainless or tool steel, it reaches it limits very quickly. I was going to use the quick code, but it is very limited, the Hurco would be alot better machine if you dont use a cam system. |
