Thread: Dowel Pins
Old 01-30-2004, 11:40 PM
DavidB DavidB is offline
DavidB is on a distinguished road
There are a lot of variables here.If the steel can be mounted together first then drilled and reamed together the alignment woukd be perfect.The holes are the same dia in both piece uasual a H7 fit.On a 1/4 dai hole i would pre drill 0.008-0.012" smaller then ream with oil.If you where to pitch both out sepperate i would pre drill and then spot with a cutter,then ream.
If the material is to hardened the reamed hole is to finished then polished if needed after heat treat.
Hope this helped
