Thread: Dowel Pins
Old 01-30-2004, 11:27 PM
Mr.Chips's Avatar
Mr.Chips Mr.Chips is offline
Gold Member
Mr.Chips is on a distinguished road
Dowel Pins
I would like some information about the installation and use of dowel pins.
Are the dowel pin holes drilled after the pieces are bolted together and aligned?
In many situations the work may be too big to fit in the drill press, what do you do then?
Are the holes in both pieces the same, or is one of the holes reamed slightly larger so it could be disassembled?
If you are using a 1/4" dowel pin, what size hole should be drilled for it? And are both holes reamed?
I'v been a hobby wood worker for years and this CNC hobby has expanded my areas of interest into metal.
Hager
