Edwardpic, I have heard others complain of dross build up on the slats as well as the change in the quality of the cut as it passes over the slat. I have cut 1" high points in my slats spaced 6" apart and staggered. My friend with the plasma cam had worked around anouther cnc plasma before getting his plasmacam which comes with pointed slats. He said the points made a big difference and to be sure to try them on my table that I built. The plasmacam software even shows the table points in the Cad part of the software. When his points ware off he he has some 1" by 3" pieces he cut with a slot in the middle and a point on the end that drops in place on the slat with the worn point . Seems to work good for him. Once my table is up and running I can give some more feedback. Keep us updated on your progress. Same for Bossfrog, and where is scorpion? |
