Kong: I don't think it is DOS, just a command line for the kernel. Tonight I am going to mess around with Partition Magic on the machine and see what I can do. The machine was blank when I started so it is not a big deal if I end up having to format the drive later.
I built the the machine specifically for running the router. The only reason I wanted XP on it was it made it simlar to the other machines in the house. Last time I built a computer it was a Z-80 machine that I soldered together on a circuit board! If I remember correctly it had am 8K memory chip on it which cost me a small fortune at the time.
I'll let you guys know how it turns out.
__________________ Paul Riedlinger
Let the chips fall where they may...I'm not going to clean them up! |
