Well heres an update:
PM 1000 came today, finished the controller connections and power connection for the PM. Everything went great. Went to do the set-up on the machine, moved gantry to the center and powered the contoller on and started the software. Red lights are on on the motors, but NO movement either X or Y, went right by the manual and nothing.
Needless to say I am not a happy camper right now. Lets hope that Dyna can tell me whats wrong and the thing will come to life. What I have noticed is the manual no where near matches the software settings wise. The help files that give you the settings are much different then the manual. Also there is an extra pin on the controller but one wire short in the plug. I spent 2 hours checking wiring and re-checking wiring. Finally gave up and went home with the machine sitting silent.
Ill post what the problem was tomorrow, if we can get it worked out. Almost seems like the software is still in symulation mode even though its registered and should work.
Wish me luck!!!
Ed |
