I know what you are talking about!
But this shouldn't matter, because that evens it out.
You must have a very light duty machine. You have taken the right Joyce, in selecting a ball cutter, it plunges good, and you should be able to cut sideways!
You can try using a 4 - fluted center cutting endmill, it should get better, less aggressive in
cutting, because there are more teeth engaged in the material.
Konrad
__________________ Use a sharp tool & cut cool ! |
